TwinTurbo.NET: Nissan 300ZX forum - adding meth injection how should i go about adjusting
Subject adding meth injection how should i go about adjusting
Posted by 94ttz32 on May 29, 2012 at 9:37 PM
  This message has been viewed 220 times.
Message Ok guys I installing a aquamist HFS3 system today and tomorrow. I already run 18.5 psi and 19 degrees timing all everyday on 93 oct knock free! The Hfs3 is a controlled system and works off injectors duty cylcle and only flows smaller abouts at lower duty and lower boost instead of one big flow rate.
So Im renting a dyno and makeing abase pull and then cutting on the system . So what should I do from their up the boost or timing or both. About what is the limits you all have seen with other set ups. Ill be running wiper fluid!. I may about 544whp on 93 alone!
