TwinTurbo.NET: Nissan 300ZX forum - figure out which wire coming off the pump assembly
Subject figure out which wire coming off the pump assembly
Posted by WhiTTe Z on May 29, 2012 at 2:01 AM
  This message has been viewed 146 times.
In Reply To I still have the stock TT pump should be fine for this setup (n/m) posted by timmaz on May 29, 2012 at 12:53 AM
Message is the 12v and then ground the other. I believe it's a white wire on mine from the harness. You can make sure by testing the voltage. The pump itself will definitely be fine for this application.
Out of curiosity why are you doing this swap? Did something happen to your TT motor?
