TwinTurbo.NET: Nissan 300ZX forum - Re: Cracked wrist pin.
Subject Re: Cracked wrist pin.
Posted by Tech@EPR on May 29, 2012 at 12:49 AM
  This message has been viewed 367 times.
In Reply To Cracked wrist pin. posted by MeatMan - 604Z.ca - on May 28, 2012 at 11:17 AM
Message Excessive detonation can/will cause wrist pin damage. In a floating pin bore, the pin being stuck and not allowed to move/spin in the bore will cause damage to the pin and or piston. Significant side load will damage the pins when running as well.
Symptoms usually aren't detectable until the pin itself finally gives way. When that happens the engine is down for the count.
Ep Racing | Create Your Badge
