TwinTurbo.NET: Nissan 300ZX forum - You can use the stock wiring if you're just driving the
Subject You can use the stock wiring if you're just driving the
Posted by JBender on May 28, 2012 at 11:59 PM
  This message has been viewed 167 times.
In Reply To stereo upgrade posted by reaperz1 on May 28, 2012 at 08:22 PM
Message speakers from the headunit. If you went with a separate amp then I would consider running a larger gauge wire to them. Assuming whoever installed your headunit used a harness like this and didn't just hack into the stock harness, you can use the speaker wires as labeled.
RTFSM - Read the Factory Service Manual
Purpose of site is to archive Z information. It is found by using search. Same reason you go to a library to read books to research a topic instead of standing in the library lobby shouting your question hoping someone has read the books your answer is in. - LordZ
Hi guys, my mechanic died before finish my car so i try to finish myself - ktranne
