TwinTurbo.NET: Nissan 300ZX forum - Looks good, just use pliers on the ends
Subject Looks good, just use pliers on the ends
Posted by EUGENE on May 28, 2012 at 11:53 PM
  This message has been viewed 159 times.
In Reply To Does this solder joint look right? posted by beanz on May 28, 2012 at 04:34 PM
Message After the joint is cold, just crush the sharp ends of the wire twists with some needle nose pliers to flatten them out. Then once they're relatively smooth, just slide some heat wrap over and heat it up with a lighter. I've reworked a lot of my connectors that way and expect them to last longer than the rest of the harness.
