TwinTurbo.NET: Nissan 300ZX forum - Yup should be two wires from the relay just
WhiTTe Z
on May 28, 2012 at 11:21 PM
I have an Aeromotive FPR with a gauge that I can adjust.
posted by timmaz
on May 28, 2012 at 11:24 AM
wire it right to the pump. Is it an in-tank pump? The Aeromotive FPR would work fine, if I were you I would have just left the TT pump.
Fuel pump question
timmaz
19:22:00 05/27/12
The TT has a 3 speed pump/controller
WhiTTe Z
04:38:42 05/28/12
timmaz
11:24:45 05/28/12
Yup should be two wires from the relay just -
WhiTTe Z
23:21:33 05/28/12
I still have the stock TT pump should be fine for this setup (n/m)
timmaz
00:53:13 05/29/12
figure out which wire coming off the pump assembly
WhiTTe Z
02:01:29 05/29/12
I would just connect a wire from the relay
WhiTTe Z
17:33:10 05/29/12
I'm doing the swap because
timmaz
18:36:03 05/31/12
