TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: issues with consult connector
Subject Re: Re: Re: issues with consult connector
Posted by Tanley on May 28, 2012 at 8:03 PM
  This message has been viewed 296 times.
In Reply To Re: Re: issues with consult connector posted by Medallion Man on May 27, 2012 at 01:44 AM
Message When you turn the ignition to on, does the check engine light come on? If so, then if I am reading the wiring diagram correctly you have a problem between where the consult connector ties in to that wire and the port. If the check engine light doesn't come on then check fuse #10 EL-9 on the main fuse block. Also is your speedo working?
