TwinTurbo.NET: Nissan 300ZX forum - Re: Anyone else had a timing belt walk back and shred?
Subject Re: Anyone else had a timing belt walk back and shred?
Posted by sak01 on May 26, 2012 at 9:30 PM
  This message has been viewed 375 times.
In Reply To Anyone else had a timing belt walk back and shred? posted by Rocket man on May 26, 2012 at 05:31 PM
Message Did you follow this write-up?
[ http://www.ttzd.com/tech/timingbelttech.html ] (step 37 discusses the crank sprocket washers)
Items I can think of that impact the belt from walking backwards are the crank washers, belt direction (arrows pointing forward), and the timing belt tensioner. The base of the idler pulleys when torqued correctly should sit flat against the block, so it's highly unlikely that they are out of alignment (but anything is possible). Hope this helps.
