TwinTurbo.NET: Nissan 300ZX forum - Turn the crank with a wrench to make sure it will turn
Subject Turn the crank with a wrench to make sure it will turn
Posted by JBender on May 26, 2012 at 1:45 PM
  This message has been viewed 249 times.
In Reply To Engine won't turn over *bangs head against wall* posted by Jinjiro on May 26, 2012 at 12:47 PM
Message Once you confirm that the engine isn't locked up, check the cables going to the starter and battery, clean the terminals and connection points up really well, and try it again.
Starter / cables are the most likely culprit.
RTFSM - Read the Factory Service Manual
Purpose of site is to archive Z information. It is found by using search. Same reason you go to a library to read books to research a topic instead of standing in the library lobby shouting your question hoping someone has read the books your answer is in. - LordZ
Hi guys, my mechanic died before finish my car so i try to finish myself - ktranne
