TwinTurbo.NET: Nissan 300ZX forum - Re: issues with consult connector
Subject Re: issues with consult connector
Posted by Tanley on May 26, 2012 at 1:32 PM
  This message has been viewed 332 times.
In Reply To issues with consult connector posted by Medallion Man on May 26, 2012 at 05:55 AM
Message Refer to this so were on the page as far as the ECM pinout goes. Did you check the ground on the connector? Use this link to confirm you are checking the right pins. Not sure if the wire colors are the same but the pins should be in the same place as noted on the bottom of this webpage.
-Tanley
