TwinTurbo.NET: Nissan 300ZX forum - Engine won't turn over *bangs head against wall*
Subject Engine won't turn over *bangs head against wall*
Posted by Jinjiro on May 26, 2012 at 12:47 PM
  This message has been viewed 457 times.
Message Gotta love these cars. =)
The Z started fine two weeks ago when I noticed a gas leak coming from somewhere. I pulled the plenum, replaced the injector o-rings and fuel clamps, and put it all back together.
Now I can't get the engine to turn over. When I turn the key, the starter engages with a thud but the flywheel won't spin. I've tried two different batteries that I know are good. I disconnected the starter, applied power, and confirmed it is working. I also checked to make sure the clutch slave cylinder is working, but I'm wondering if the clutch line needs to be bled or adjusted? I did put in a HD clutch fork last month, so I'm wondering if that is throwing the adjustment off.
The weird thing is it started ok several times after I put the new fork in. I don't get why the clutch would be adjusted & working, and then stop working without me messing with it.
