TwinTurbo.NET: Nissan 300ZX forum - I would start with the fronts, as there will be a ton of
Subject I would start with the fronts, as there will be a ton of
Posted by zgene4 on May 26, 2012 at 10:42 AM
  This message has been viewed 112 times.
In Reply To Quick question about bleeding brakes posted by dvice on May 26, 2012 at 01:10 AM
Message air in the calipers and front lines. Once you get clean fluid with no air from the front bleeders, I would move to the rears (passenger, then driver). It's possible the rears won't be affected at all because they're plumbed from a single hardline that runs all the way back to the master cylinder, but it depends on how much fluid you lost during the front install and if enough air got into the system. It's really not a bad idea to clean out the rears of any old fluid and possible air bubbles and should only take a few pumps on each corner.
WARNING: I lack industry backing
