TwinTurbo.NET: Nissan 300ZX forum - From what I have been told, Gas in your oil is due to excess
Subject From what I have been told, Gas in your oil is due to excess
Posted by Red Hawk (CO) on May 25, 2012 at 10:43 AM
  This message has been viewed 145 times.
In Reply To Ok posted by 300ZMang on May 25, 2012 at 10:05 AM
Message blowby from your piston rings. I would suggest getting a compression test done. But just to re-itterate, the only way into the crankcase is either through the oil cap, through blowby past the piston rings, or backwards through your pcv system. Leaking injectors can cause gas in your oil, but that is strictly because gas is pooling in your cylinders when the car is off and slowly leaking by your rings (same concept as blowby)
TT BEAST IN PROGRESS!
