TwinTurbo.NET: Nissan 300ZX forum - Sounds like the starter is not fully engaging the flywheel
Subject Sounds like the starter is not fully engaging the flywheel
Posted by JBender on May 24, 2012 at 1:01 PM
  This message has been viewed 241 times.
In Reply To loud grinding noise when starting. posted by jjames69 on May 24, 2012 at 11:23 AM
Message Yank the starter and bring it to an auto parts store to have it tested. While you're down there, inspect the teeth on the ring gear to make sure they aren't too damaged. If a good portion of the teeth are worn down, you will have to replace the flywheel, or else a new starter will still have engagement issues.
RTFSM - Read the Factory Service Manual
Purpose of site is to archive Z information. It is found by using search. Same reason you go to a library to read books to research a topic instead of standing in the library lobby shouting your question hoping someone has read the books your answer is in. - LordZ
Hi guys, my mechanic died before finish my car so i try to finish myself - ktranne
