TwinTurbo.NET: Nissan 300ZX forum - Re: General thoughts...
Subject Re: General thoughts...
Posted by Notgonnablowthemotor on May 22, 2012 at 7:38 AM
  This message has been viewed 127 times.
In Reply To General thoughts... posted by beanz on May 21, 2012 at 09:36 PM
Message Thanks for the detailed follow up. I got new spark plugs and am going to be replacing all 6 tonight. It's running rather rich, the exhaust smoke only comes from the driver's side when it does. This is the same side as the new fuel injector and the PFR5-11B spark plug.
This drives me to assume there is an issue with it. I'd rather not sit through another entire plenum pull for another injector unless I have to. I know it's really a shot in the dark with this spark plug, but I read another issue online that was causing a similar problem to another person's Z till the plugs got changed.
I did check the single PFR5B-11B last night and it wasn't fouled.
List of known mods
Chipped ECU by Jim Wolf for 14psi
Underdrive Pulleys
Full Borla Exhaust
Stage 2 Clutch
