TwinTurbo.NET: Nissan 300ZX forum - Follow specialty Z's guide for adjusting your clutch.
Subject Follow specialty Z's guide for adjusting your clutch.
Posted by doug8867 on May 21, 2012 at 1:27 PM
  This message has been viewed 160 times.
In Reply To hard to get into gear when car warms up after clutch install posted by dtoyvr6 on May 21, 2012 at 11:42 AM
Message It almost always has to be done after a clutch replacement because the new clutch is thicker than the worn down removed clutch, therefor it's engagement point will be different.
That being said, the fact that the pedal height changes after the car is warmed up suggest you still have air in the lines. Make sure you bleed from both points to ensure air is released.
