TwinTurbo.NET: Nissan 300ZX forum - Re: I checked the TPS it read 0.46v I also checked
Subject Re: I checked the TPS it read 0.46v I also checked
Posted by nismotech on May 21, 2012 at 11:54 AM
  This message has been viewed 189 times.
In Reply To I checked the TPS it read 0.46v I also checked posted by JOZ32 on May 21, 2012 at 08:12 AM
Message the MAF can fail in different ways most likly causing what you described bogging while reving but can also cause engine to run like crap in general. Another thing to check would be the ignition module forget the proper name but it's mounted on the top T-belt cover. could be weak spark. Do you have a scan tool that you can moniter data?
