TwinTurbo.NET: Nissan 300ZX forum - hard to get into gear when car warms up after clutch install
Subject hard to get into gear when car warms up after clutch install
Posted by dtoyvr6 on May 21, 2012 at 11:42 AM
  This message has been viewed 257 times.
Message Ok so I did a clutch and flywheel install. Both rps max street and flywheel. The shifting was perfect before the install. Put everything back up just as it was and as soon as the car warms up it is so hard to get it into all gears and it feels like the clutch feel from the pedal changes a bit as in where the clutch engages as soon as I lift my foot. If the car is off or cold the gears go in perfectly. I bled the lines numerous times and still hasn't changed. I've searched and seen that ppl adjusted their pedals and that worked and some even changed their slave with a longer rod and that fixed the prob. The clutch is a slightly used piece but was in very good condition. I saw some say their pressure plate was bad also. I hope its not that. Anybody else have this problem recently? Thank you
