TwinTurbo.NET: Nissan 300ZX forum - Re: Fuel Injector
Subject Re: Fuel Injector
Posted by keptman on May 21, 2012 at 11:20 AM
  This message has been viewed 157 times.
In Reply To Fuel Injector posted by Notgonnablowthemotor on May 20, 2012 at 04:08 PM
Message could posible be a leaking o ring on the injector that was fixed. it will clear up when at high rpm and foul out at idle.
First thing to check is oil level. if it overfull could be from fuel.
second pull spark plug out of cylinder after you have it doing symptom. if the plug wet it's leaking. I've seen guys try to use old orings and get this result.
