TwinTurbo.NET: Nissan 300ZX forum - Re: Can a bad o2 sensor cause erratic idle ?
Subject Re: Can a bad o2 sensor cause erratic idle ?
Posted by nismotech on May 21, 2012 at 7:15 AM
  This message has been viewed 280 times.
In Reply To Can a bad o2 sensor cause erratic idle ? posted by JOZ32 on May 20, 2012 at 01:10 PM
Message it's possible but i'm thinking you have more than that check the tps voltage and closed throttle position. Also possible bad MAF and if it runs this way before closed loop most likly not an o2 issue. Do basic checks timing, base idle etc.
