TwinTurbo.NET: Nissan 300ZX forum - Re: I run AVS 18x9.5 on the rear...
Subject Re: I run AVS 18x9.5 on the rear...
Posted by nismotech on May 19, 2012 at 1:56 PM
  This message has been viewed 122 times.
In Reply To I run AVS 18x9.5 on the rear... posted by beanz on May 17, 2012 at 04:44 PM
Message not that i think you are dumb but, example tire size 275/35r-18 means the tire is 275mm wide and the sidewall measurement of 35 means the sidewall height is 35% of the tread width (275mm) so maybe that can help if you mount the rim and take measurments
