TwinTurbo.NET: Nissan 300ZX forum - Re: 100 or 4.7
Re: 100 or 4.7
gbeto
on May 19, 2012 at 1:20 PM
100 or 4.7
posted by gbeto
on May 19, 2012 at 01:17 PM
the array takes 3 AAA batteries, 5 led lights, I assume it does have a resistor build in, may I just wire it to accept the + and - from the injector wire?
Injector problem
gbeto
14:19:07 05/17/12
Check continuity though the harness to the ECU.
Draker (Eugene, OR)
17:19:39 05/17/12
O-scope or Noid Lights
OverZealous (CT)
17:21:10 05/17/12
looking into this noid light.
gbeto
17:59:56 05/17/12
FYI - Just a simple LED with a resistor will let you run
jzack
22:28:51 05/17/12
Re: FYI - Just a simple LED with a resistor will let you run
gbeto
00:01:50 05/18/12
Pretty much any bright red LED will work along with a 1k or
jzack
21:00:31 05/18/12
100 or 4.7
gbeto
13:17:39 05/19/12
Re: 100 or 4.7 -
gbeto
13:20:51 05/19/12
Might be able to use AC Voltmeter if you get smart
OverZealous (CT)
17:25:21 05/17/12
no the wire.
gbeto
14:51:49 05/20/12
Check the PTU
OverZealous (CT)
20:27:28 05/21/12
i meant
gbeto
01:05:11 05/23/12
