TwinTurbo.NET: Nissan 300ZX forum - Pretty much any bright red LED will work along with a 1k or
Subject Pretty much any bright red LED will work along with a 1k or
Posted by jzack on May 18, 2012 at 9:00 PM
  This message has been viewed 200 times.
In Reply To Re: FYI - Just a simple LED with a resistor will let you run posted by gbeto on May 18, 2012 at 12:01 AM
Message so resistor. Would be a good idea to add another regular diode (1n1004 or similar) in series with the red LED. That 2nd diode acts as reverse polarity protection should the + and - car connections get reversed by accident when connecting the test light to the car.
I'd stay away from the white or blue super bright type LEDs - they tend to be a little more static sensitive and more easily damaged in a test environment....
