TwinTurbo.NET: Nissan 300ZX forum - Oil pressure sensor wiring!!!
Subject Oil pressure sensor wiring!!!
Posted by JonnyZ(SoCal) on May 17, 2012 at 9:16 PM
  This message has been viewed 516 times.
Message I was not able to locate on my harness where to re wire my sensor.
As a temporary solution, can I make my own connection straight to sensor from the stock pressure gauge... Or does it need to run through the harness/ecu and a resistor or something.
I just need it to make sure I get pressure upon my first startup. So if this won't work can I just use an aftermarket gauge?
Thanks in advance for any help!
