TwinTurbo.NET: Nissan 300ZX forum - Re: W/O an air leak, throttle adjustment screw on IACV turned
Project_Broke
on May 16, 2012 at 12:43 PM
posted by Gordo 93TT Daytona
on May 15, 2012 at 05:42 PM
I'll pull the plenum off and check everything. Any way to tell where an air leak was at on the gasket? I can't hear air entering anywhere, so no idea where to start.
Weird idle issue, vacuum line hell, and other problems
Project_Broke
09:07:27 05/15/12
Did you set the base idle using the idle adjustment screw? (n/m)
Draker (Eugene, OR)
10:54:13 05/15/12
Re: Did you set the base idle using the idle adjustment screw?
Project_Broke
14:47:53 05/15/12
Did you unplug the IACV?
Draker (Eugene, OR)
15:35:19 05/15/12
Re: Did you unplug the IACV?
Project_Broke
16:30:26 05/15/12
If you think it's faulty, then ohm it out.
Draker (Eugene, OR)
16:39:21 05/15/12
Gordo 93TT Daytona
17:42:30 05/15/12
Re: W/O an air leak, throttle adjustment screw on IACV turned -
Project_Broke
12:43:46 05/16/12
you usually won't hear a large air leak. It's too large
doug8867
14:17:11 05/16/12
You have a large air leak.
doug8867
09:20:43 05/16/12
