TwinTurbo.NET: Nissan 300ZX forum - Self learn and A/F alphas
Subject Self learn and A/F alphas
Posted by beanz on May 15, 2012 at 4:42 PM
  This message has been viewed 175 times.
Message I am trying to understand how the ECU calculates A/F alphas. I did a lot of searching on this. I might be wrong about a lot of what I think I know, but here are my questions.
I understand that the O2 sensors indicate to the ECU if the AFR is rich or lean as a deviation from a stoichiometric mixture.
If I understand A/F alphas, they exist to nudge the mixture richer or leaner by a constant percentage across the closed loop region in the fuel maps. The idea being that the TPs in the fuel map aren't always going to be 100% accurate (with a basis on a stoichiometric mixture) due to slight variations in the performance of various sensors and parts.
Since almost none of the fuel map actually calls for a stoichiometric mixture, the existence of A/F alphas seems to indicate that the ECU is capable of determining if a fuel map enrichment/enleanment value actually produced the desired mixture as a deviation from a stoichiometric one.
In other words, if a fuel map cell actually called for a 14.7:1 AFR, then we could just nudge fuel one way or the other in some programatic way until the O2 sensor voltage was one that we know always indicates a stoichiometric mixture. But I think only a small number of fuel map cells, at least on my aftermarket ECU, actually call for a mixture near 14.7:1, exactly.
Assuming that's not all totally wrong, my question is: how does the ECU determine the AFR for a given O2 sensor voltage reading, which I think it'd need to know in order to work backwards to determine if its TP is actually generating a stoichiometric mixture? Is it just a simple calculation within the narrowband the stock O2 sensor works in, based on the assumption that some value (~450mV I think?) indicates a stoichiometric mixture?
Thanks.
Andy
  • Self learn and A/F alphas - beanz 16:42:03 05/15/12
