TwinTurbo.NET: Nissan 300ZX forum - Re: Did you set the base idle using the idle adjustment screw?
Project_Broke
on May 15, 2012 at 2:47 PM
Did you set the base idle using the idle adjustment screw? (n/m)
posted by Draker (Eugene, OR)
on May 15, 2012 at 10:54 AM
No matter what I do with that screw, it makes minimal difference. It changes maybe 100 rpm all the way in from out. It's almost like it doesn't work at all. I have it set as high as I can, still won't idle without throttle.
Weird idle issue, vacuum line hell, and other problems
Project_Broke
09:07:27 05/15/12
Draker (Eugene, OR)
10:54:13 05/15/12
Re: Did you set the base idle using the idle adjustment screw? -
Project_Broke
14:47:53 05/15/12
Did you unplug the IACV?
Draker (Eugene, OR)
15:35:19 05/15/12
Re: Did you unplug the IACV?
Project_Broke
16:30:26 05/15/12
If you think it's faulty, then ohm it out.
Draker (Eugene, OR)
16:39:21 05/15/12
W/O an air leak, throttle adjustment screw on IACV turned
Gordo 93TT Daytona
17:42:30 05/15/12
Re: W/O an air leak, throttle adjustment screw on IACV turned
Project_Broke
12:43:46 05/16/12
you usually won't hear a large air leak. It's too large
doug8867
14:17:11 05/16/12
You have a large air leak.
doug8867
09:20:43 05/16/12
