TwinTurbo.NET: Nissan 300ZX forum - Air can leak into the system w/o brake fluid leaking out.
Subject Air can leak into the system w/o brake fluid leaking out.
Posted by Gordo 93TT Daytona on May 14, 2012 at 11:37 AM
  This message has been viewed 212 times.
In Reply To Clutch still not working posted by rojoloco (VA Beach) on May 12, 2012 at 12:15 PM
Message You do not need to source a pool of brake fluid to have a condition wherein air is being sucked into the system and creating air bubbles in the hydraulic line. It takes a very small pocket of air to collapse the pressure, and that amount of air could easily displace an equal amount of fluid by backing up into your brake cylinder reservoir. Ergo, the condition goes unnoticed... except for the obvious drop in line pressure and loss of clutch function.
_________________________________________________
