TwinTurbo.NET: Nissan 300ZX forum - The slave pin should extend at least 3/4" of travel.
Subject The slave pin should extend at least 3/4" of travel.
Posted by Gordo 93TT Daytona on May 13, 2012 at 9:01 PM
  This message has been viewed 175 times.
In Reply To It does pivot. posted by rojoloco (VA Beach) on May 12, 2012 at 08:11 PM
Message I am estimating from previous experience, so this dimension is not an exact figure. However, if the pin is only extending a 1/4" or so, the problem is most likely in the hydraulics. If you get closer to an inch of travel out of the slave, then the fork pivot pin, clutch fork and/or clutch pressure plate fingers need to be examined.
_________________________________________________
