TwinTurbo.NET: Nissan 300ZX forum - First off I would not cut a sensor tip. Second, I would
Subject First off I would not cut a sensor tip. Second, I would
Posted by Gordo 93TT Daytona on May 13, 2012 at 8:55 PM
  This message has been viewed 128 times.
In Reply To Can custom temp sensor be cut and work fine if too long? posted by qcsolo on May 12, 2012 at 02:05 PM
Message not use the location at the rear of the cylinder head because coolant at that location will always be extremely hot, regardless of your overall system temp. How are you going to know if your system is overheating when the location you chose to monitor is always hottest part of the system?
Most people use an adapter hard pipe inserted into the front rubber hose coming off the water pipe.
_________________________________________________
