TwinTurbo.NET: Nissan 300ZX forum - NO. They should not swell at all.
Subject NO. They should not swell at all.
Posted by ZXoltan on May 13, 2012 at 12:23 PM
  This message has been viewed 162 times.
In Reply To As a follow up; the problem seems to have solved itself. posted by pa300 on May 13, 2012 at 09:33 AM
Message If the Orings you've got have swelled, then they are the wrong type. The factory O-rings (Nitrile), Viton, or HNBR rings will not swell in contact with fuel. Other materials probably will though. If you used hardware store o-rings, that is your issue and you need to correct before you have some serious engine damage.
