TwinTurbo.NET: Nissan 300ZX forum - Not common based on my experience with the Z injectors>>
ZUL8TR
on May 13, 2012 at 12:21 PM
As a follow up; the problem seems to have solved itself.
posted by pa300
on May 13, 2012 at 09:33 AM
The Orings should be leak proof from the start. But if it took 2 days and no fires occured that's great. Keep a nose on it. ;)
ZUL8TR in Orlando,FL
Injector o-ring question...
pa300
20:30:38 05/12/12
Re: Injector o-ring question...
njz
21:00:00 05/12/12
Ok, understand which is the lower oring now but....
pa300
21:08:41 05/12/12
It's leaking from the fuel rail, the o-rings top and bottom
njz
21:22:59 05/12/12
Oh, sorry this is on a 2001 cavalier. Thanks for the help.
pa300
21:37:36 05/12/12
Then you have an injector leaking (n/m)
njz
21:58:39 05/12/12
OK, thanks, I'll try switching out for the old ones..
pa300
22:02:33 05/12/12
Use vasoline as a lube so Oring does not pinch. (n/m)
ZUL8TR
09:31:20 05/13/12
pa300
09:33:25 05/13/12
Not common based on my experience with the Z injectors>> -
ZUL8TR
12:21:29 05/13/12
Actually this is on a 2001 cavalier...
pa300
16:50:50 05/13/12
NO. They should not swell at all.
ZXoltan
12:23:53 05/13/12
This on on my DD cavalier. The orings were the ones supplied
pa300
16:54:45 05/13/12
pa300
16:55:04 05/13/12
