TwinTurbo.NET: Nissan 300ZX forum - Can custom temp sensor be cut and work fine if too long?
Subject Can custom temp sensor be cut and work fine if too long?
Posted by qcsolo on May 12, 2012 at 2:05 PM
  This message has been viewed 128 times.
Message I'm adding (TT) a custom temp gauge providing OEM one is not precise enough.
The best pick-up location is on rear engine water tube going to passemger head but would like to avoid welding a NPT plug to it.
There is a rubber hose connecting the same tube which I have bought a "T" adapter with a female NPT but the sensor having about 1/4" x 1/2" long does block 90% of the hose inside diameter when it will be installed.
Does someone know if i can cut using a steel handsaw, the sensor lenght to 1/4" long to avoid blocking water passage into the tube without any temp error issue or permanently damage the sensor doing it ?
Thanks
