TwinTurbo.NET: Nissan 300ZX forum - OEM bolts are two (2) sizes:
Subject OEM bolts are two (2) sizes:
Posted by Gordo 93TT Daytona on May 11, 2012 at 10:29 AM
  This message has been viewed 254 times.
In Reply To Front Camber Correction Kit Specs? posted by AsaHerring on May 08, 2012 at 11:41 PM
Message 10x1.25 x 26mm (1" long plus you need to add length for added shim thickness and washers on both sides)
12x1.25 x 70mm (1.75" long plus added thickness for shims and washers)
I'd pull the brackets off and take the bolts will you to buy new ones. FYI the 300 Degree kit will accomodate up additional shims up to about 0.70".
_________________________________________________
