TwinTurbo.NET: Nissan 300ZX forum - The knock sensor circuit is very sensitive!
Subject The knock sensor circuit is very sensitive!
Posted by OverZealous (CT) on May 10, 2012 at 9:15 PM
  This message has been viewed 321 times.
In Reply To How can I rewire knock sensor from subharness plug to ECU?? posted by 91FairladyTT on May 10, 2012 at 11:09 AM
Message I don't know how much you'd degrade its functionality by omitting the shielding but I assure you it will degrade its functionality some.
The other folks are absolutely correct, test before re-wiring.
The second pin on the knock sensor is not needed because the sensor itself is grounded. The second pin has absolutely nothing to do with the shielding. It's simply a redundant design: ground the sensor or use the extra pin. Knowing which pin is the right one, however, is not straight forward. I'm working on a detailed write-up to explain this.
OverZealous (CT)
My General posts (click)
My Technical posts (click)
