TwinTurbo.NET: Nissan 300ZX forum - The more I search the more I think the input shaft bearing
Evan_Wright (Ca)
on May 10, 2012 at 11:50 AM
Mine has a slight amount of play, way less than yours though
posted by EUGENE
on May 10, 2012 at 11:39 AM
is the issue. I have a pretty load "whirring" noise while in neutral with clutch pedal up. The noise goes away when I depress the clutch pedal.
Is it normal to have some play in the input shaft of the
Evan_Wright (Ca)
19:03:51 05/09/12
Video:
Evan_Wright (Ca)
20:56:44 05/09/12
That amount of lateral play is excessive. In and out is >>
ZUL8TR
15:12:29 05/12/12
PS what brand, type and grade gear oil are you using? >>>
ZUL8TR
15:15:18 05/12/12
EUGENE
11:39:16 05/10/12
The more I search the more I think the input shaft bearing -
Evan_Wright (Ca)
11:50:25 05/10/12
Mine did the same thing.
Drk93TT
21:22:22 05/10/12
mine sounds the same
aliaZ
07:15:35 05/11/12
Wow, that's is pretty bad. Maybe I shouldnt be complaining
Evan_Wright (Ca)
08:35:38 05/11/12
what was wrong with your input shaft?
aliaZ
21:08:22 05/12/12
end play is required for the transmission to rotate (n/m)
sandmanz32
19:00:33 05/10/12
