TwinTurbo.NET: Nissan 300ZX forum - Mine was leaking from the high pressure hose as well as
Subject Mine was leaking from the high pressure hose as well as
Posted by Jayru on May 09, 2012 at 8:56 PM
  This message has been viewed 423 times.
In Reply To Which of my power steering hoses is leaking? posted by Marshall on May 09, 2012 at 08:25 PM
Message the lower pressure hose. (and at the pump too!) The low pressure hose is a compression fitting onto the hardline that wears over time (and it's facing down). So it can and will still leak.
I would think your high pressure hose may not be the problem as it would soak your alternator (mine was). Check the LP line and the wadhers at the pump like TDogg said.
90 Twin Turbo Track Build - jsworks.org for more info!
