TwinTurbo.NET: Nissan 300ZX forum - I'd do the paper towel test first.
zellamay
on May 09, 2012 at 6:57 PM
Good idea. Tried the procedure
posted by hunterg
on May 09, 2012 at 05:13 PM
If you're smelling gas that readily, it's leaking to the atmosphere, either via injector o-rings or hose connections. You might get lucky and find a loose connection. I'd do both tests before taking anything apart.
Hard to start and strong fuel smell
hunterg
13:13:35 05/09/12
First check to see if you are losing fuel pressure
Draker (Eugene, OR)
13:24:26 05/09/12
If you can't see the leak, you can use the paper towel
zellamay
13:44:23 05/09/12
Thanks for the leads
hunterg
15:55:35 05/09/12
Do this
Draker (Eugene, OR)
16:29:36 05/09/12
hunterg
17:13:48 05/09/12
It's an oring then
Draker (Eugene, OR)
18:37:28 05/09/12
I'd do the paper towel test first. -
zellamay
18:57:09 05/09/12
location of return fuel return line? send line?
Jiro
01:38:44 05/12/12
