TwinTurbo.NET: Nissan 300ZX forum - First check to see if you are losing fuel pressure
Draker (Eugene, OR)
on May 09, 2012 at 1:24 PM
Hard to start and strong fuel smell
posted by hunterg
on May 09, 2012 at 01:13 PM
You need to see if you lose pressure with the key off. Hook up a gauge and watch it. If you are losing fuel pressure, find out if it's a leaking injector oring, leaking out of a fuel line or leaking at the fuel pump.
hunterg
13:13:35 05/09/12
First check to see if you are losing fuel pressure -
Draker (Eugene, OR)
13:24:26 05/09/12
If you can't see the leak, you can use the paper towel
zellamay
13:44:23 05/09/12
Thanks for the leads
hunterg
15:55:35 05/09/12
Do this
Draker (Eugene, OR)
16:29:36 05/09/12
Good idea. Tried the procedure
hunterg
17:13:48 05/09/12
It's an oring then
Draker (Eugene, OR)
18:37:28 05/09/12
I'd do the paper towel test first.
zellamay
18:57:09 05/09/12
location of return fuel return line? send line?
Jiro
01:38:44 05/12/12
