TwinTurbo.NET: Nissan 300ZX forum - Actually a common problem -- I never replaced that
Subject Actually a common problem -- I never replaced that
Posted by jzack on May 08, 2012 at 10:02 PM
  This message has been viewed 121 times.
In Reply To ECU Code 34 culprit? posted by Stokens (StoMoZTT) on May 08, 2012 at 09:12 PM
Message connector, instead I just substituted using male/female crimp on spaded connectors (after removing the oem connectors on both sides). Used heat shrink tubing over the crimp ends for better moisture protection -- has been fine for 4 years now and tucks away nicely behind/under the balance tube....
I reversed the male/female ends on black vs white wires - that way the 2 can't be mixed up if taken apart. If needed that damaged wire can be extended a little bit too so the wire ends are the same length...
