TwinTurbo.NET: Nissan 300ZX forum - Another Cruise Control Question - 93 auto tt
Subject Another Cruise Control Question - 93 auto tt
Posted by dan93z on May 07, 2012 at 8:41 PM
  This message has been viewed 134 times.
Message While the brake pedal is depressed, what happens if the cruise control "on" button is pressed? I have not found any post/replies why the cruise light on the dash/pod will not stay engaged once I release the cruise "on" control button. I have not tried to hold the "on" button and set the cruise. The system has not worked since I've owned it and the previous owner did install turbo timer, keyless entry, and auto start. The switch does contact brake pedal, horn and reverse lights work. I did run across an older post about auto start being an issue. Thanks and sorry for the long post.
