TwinTurbo.NET: Nissan 300ZX forum - When you pressurize make a closed loop of the in fuel line >
Subject When you pressurize make a closed loop of the in fuel line >
Posted by ZUL8TR on May 07, 2012 at 4:35 PM
  This message has been viewed 176 times.
In Reply To If you're leaking fuel from an injector and you can smell posted by Haasz32 on May 07, 2012 at 10:33 AM
Message after the filter and the return line to the tank install apressure gage in the loop and an air pump. Be sure to place a shut off valve after the air pump to prevent air bleed back thru the air pump. So pump it up and then close that valve to isolate the loop.
ZUL8TR in Orlando,FL
