TwinTurbo.NET: Nissan 300ZX forum - Broken Ring Landings best case if it did detonate bad enough
Subject Broken Ring Landings best case if it did detonate bad enough
Posted by MixManMash on May 04, 2012 at 11:39 AM
  This message has been viewed 136 times.
In Reply To THANKS posted by blackomega on May 04, 2012 at 11:20 AM
Message Your best bet is to do a compression test and see if you are losing compression in one cylinder. Then, on the suspect cylinder, do a leak down test to figure out if it is leaking past the piston, intake or exhaust valves.
Good luck.
