TwinTurbo.NET: Nissan 300ZX forum - Boost Controller Issues
Subject Boost Controller Issues
Posted by Poppe on May 04, 2012 at 9:53 PM
  This message has been viewed 162 times.
Message In the process of my TT swap, I bought a used Greddy Profec B Type S (works exactly the same as the Spec II, but doesn't have an LCD screen). The controller doesn't seem to work - I can only boost to 7 psi regardless of what I set the gain and max boost at.
I have no boost leaks, checked 2x. I also bought a new solenoid that I confirmed is working by blowing through it and testing with a 9 volt battery. I'm beginning to suspect the head unit.
What are the proper voltages that should be coming out of the green and white wires that feed the solenoid when the boost controller is off? When on? When max boost has hit?
