TwinTurbo.NET: Nissan 300ZX forum - My auto trans issue has been cured (shifting out of or no
Subject My auto trans issue has been cured (shifting out of or no
Posted by ELDIABLO on May 06, 2012 at 6:58 PM
  This message has been viewed 175 times.
Message O/D)
I recently installed an eBay purchased auto transmission and I was having transmission issues. The transmission would either not shift into O/D or it would shift erratically between 3rd and 4th gear. For the most part I was unable to do the auto trans self diagnostic, but I lucked out and one time it did give me a code which pointed to my TPS. I tested the TPS and then when it was between 0.4 - 0.5 V there was continuity issues at the switch end of the TPS. I purchased a new one, think my current one was bad. After installing and setting up the voltage, I was still having the issue. After comparing the two units, I determined that the TPS were fine, they were just not adjusted properly. I had to adjust the TPS so that there was continuity at the switches top two pins when at idle. After adjusting the switch, the highest voltage I could get was 0.37V.
After adjusting it, I had to drive it twice for it to correct it self, but it is now driving and shifting perfect!
SIDE NOTE: For the past season until recently my Z's steering felt loose/wandered at highway speeds. Adjusting the TPS has cured that too!!
Sydney Small
Soy dios y soy el diablo
  • My auto trans issue has been cured (shifting out of or no - ELDIABLO 18:58:06 05/06/12
