TwinTurbo.NET: Nissan 300ZX forum - Rear caliper bleeding problem.
Subject Rear caliper bleeding problem.
Posted by Mecha300zx on May 06, 2012 at 3:19 PM
  This message has been viewed 152 times.
Message So I attached my engine bay brake lines that run across the furewall after spraying the engine bay with new paint. When I come to Bleed the system starting with the rear calipers I get no type of bubbles or brake fluid coming out. So I'm assuming that maybe it's my brake master cylinder thats just stop working. So we attemp to see if any fluid will come out of the front calipers after pumping the brake pedal. I open up the brake valve and fluid Shoots out of it like should. So I'm a little dumbfounded as to why fluid will come out of the front and not the rear. And yes I have covered my bases to see if there are any leaks in any of the brake lines that run through out the whole car. But no dice. Also I disconnected the lines that are attached to the rear calipers to see that if I step on the brake pedal fluid will come out but again nothing.
So I ask is it my abs system. Our there nipples on it that need to be bleed. If you can guide me in the right direction as to if I'm not doing Something that I should. Thanks again
