TwinTurbo.NET: Nissan 300ZX forum - Here is link to service manual on the brake booster>>>
Subject Here is link to service manual on the brake booster>>>
Posted by ZUL8TR on May 06, 2012 at 10:53 AM
  This message has been viewed 187 times.
In Reply To Re: ZUL8TR posted by joe645733 on May 05, 2012 at 04:25 PM
Message B4 removing do the further tests noted to be absolutly sure if the booster is bad. Based on what you are experiencing I believe the booster is bad.
Removal is straight forward and not near the PITA of a plenum pull. Note the schematic of the assembly in the service manual in the link below. The master cylindere must come out as well as the 4 nuts under the dash that secure the booster to the pedal assembly. Definately a tight spot and tedious. But patience and a few beers will get it done. Might need a helper to reassemble the booster to the pedal assembly.
[ http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=br&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=8&design=default&total=56 ]
ZUL8TR in Orlando,FL
