TwinTurbo.NET: Nissan 300ZX forum - TT pump is 2 chambers, double the size of the NA.
Subject TT pump is 2 chambers, double the size of the NA.
Posted by Chickan on May 04, 2012 at 8:29 PM
  This message has been viewed 114 times.
In Reply To Diff between TT & NA power steering pump posted by 1911a1 on May 04, 2012 at 05:39 PM
Message the first chamber is about the same between them though. The FSM has an assembly guide showing the two different pumps.
The reservoir for the TT has an extra return in it, so if you are using an NA pump you'll need NA reservoir.
