TwinTurbo.NET: Nissan 300ZX forum - Only thing I could suggest based on what you've typed
Subject Only thing I could suggest based on what you've typed
Posted by 300ZMang on May 04, 2012 at 12:21 PM
  This message has been viewed 138 times.
In Reply To Weird injector resistance...? (new style injectors) posted by AHos(Chicago) on May 04, 2012 at 12:03 PM
Message is your setting is wrong on your DMM. Make sure your range is small enough to fall in the 10-14 Ohm range. However, even if your range is off, you should still get a reading (not zero).
Damn injectors!!!!
