TwinTurbo.NET: Nissan 300ZX forum - Weird injector resistance...? (new style injectors)
Subject Weird injector resistance...? (new style injectors)
Posted by AHos(Chicago) on May 04, 2012 at 12:03 PM
  This message has been viewed 309 times.
Message Ok so as per my post in the general section, My cylinder 2 isn't firing.
Visually checked for spark - Got spark
Checked the plug for fuel - No fuel...
installed new style injectors 2 weeks ago. Got them from Bernie, cleaned and tested. Before installing them, I ohmed each one and all were around 11.4 ohms.
Ohm cylinder 2 injector... Got 4.23 ohms. seems VERY low, even for a bad injector.
Ohm other cylinders (that ARE firing) got 0 ohms..?
What am I doing wrong?
New DMM (plus it ohmed them correctly 2 weeks ago), so I dont think its my multimeter.
Why am I getting 0 ohms for working injectors.
Going off the fact that I am getting a different reading for the cylinder that isnt firing, as of right now I'm assuming that that is my problem.. Should I be thinking otherwise? or could this just mean that the resistance is higher than the good injectors, thus meaning that it is higher than 12 ohms normally?
